Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Water Problem with Air Compressor
Old 05-04-2007, 02:53 PM
71gtx 71gtx is offline
Last journal entry: Rear End Disassembly
Hello guys, I am pretty new to painting cars. I am working on a project spraying with a gravity feed gun. I have a craftsman vertical 33gallon air compressor. I purchased a craftsman water trap/filter and mounted it stratight off of the compressor before attempting spraying. I used a hose that has the hard plastic outer shell. Well, I got water bubbles heavily in the area I tested.
I then took a DA and ran it and noticed that water was coming out heavily, but no water is collecting in the water trap. i was told i need a rubber flex hose rather than the one i have, but why isn't water trapping in the first place? any tips on how to set this up to eliminate all water?
I was also told to mount the water trap higher than the compressor to help?
