Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Water Problem with Air Compressor
Old 05-05-2007, 12:38 PM
Rambo_The_Dog's Avatar
Rambo_The_Dog Rambo_The_Dog is offline
Last journal entry: Shop Remodel Progress
Originally Posted by 71gtx
Ok it seems to be hitting me now. I am going to run a hard line from the tank about 15' or so? What type of line is this called, and will any bends or angles up or down help this? Then attach the filter to the end of this hard line, run 50' hose off of that with a disposable filter attatched to the gun. Is this correct?
You can never have too many filters but place them at the end of the pipe run before the plug in for the hose...
This is a picture of my temp setup - I'll still add an air-line dryer down the road when I build an outside shed for the compressor...
This is about 100 bucks worth of copper pipe and fittings with a 50' reel hose (Lowes not sure on price its about 4 years old), the filter/regulator is from HF about 30.00
My shop is 22x40 so the retractable hose reaches all corners easily.
Copper works better for condensing the water than galvanized pipe. IMHO
