Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Water Problem with Air Compressor
Old 05-06-2007, 08:53 AM
Rambo_The_Dog's Avatar
Rambo_The_Dog Rambo_The_Dog is offline
Last journal entry: Shop Remodel Progress
Originally Posted by 71gtx
Ok guys, I purchased the goods and am about to set it up. Heres what I'm doing:
I couldn't find threaded copper pipe so I went with galvanized. I have 10 3' galvanized pipes, going to go up and down 5 times like in Rambo's picture. At the bottom of each I will have a 5" T going down to a ball valve drain. So there will be 4 drain valves and finally the craftsman filter at the end.
Galvanized pipe does not cool as well as copper - but should still give you enough to condensate the water on your down runs
btw you have to sweat/solder copper pipe together I've never seen any pipe that had threads.
Make sure you use a ball valve from the compressor to the flex hose that hooks into this system. If you ever get a blowout you want to be able to cap it off!
