Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Water Problem with Air Compressor
  #19 (permalink)
Old 05-07-2007, 07:57 AM
SteveU SteveU is offline
Make sure your connections are doped with pipe dope & tighten them up with at least 18" pipe wrenches, I used 24" on mine & haven't had any problems. If you used pliers or something other than pipe wrenches to tighten it up the problem may be that they aren't tight enough.
