Another problem may be the fittings that's why I said earlier to use a good quality fitting (such as Ward) which is not always easy to find. The pipe and fittings should be bought from a plumbing supply and not the local McHome store because of the cheap import fittings that all too often have very rough poorly cut threads that are hard to seal, same goes for the pipe make sure the threads are cut clean.
