well, i finally got it all leak proof and i ended up going the copper route. it wasn't too bad sweating the pieces together, i used the fittings with the solder already built in so it just required flux and heat. so thanks guys for all your help. i built it pretty similar to rambo's setup. lastly, what psi's should i run before the piping and after the piping for best water filtration and paint work?
