Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Water Problem with Air Compressor
  #23 (permalink)
Old 05-08-2007, 07:12 PM
71gtx 71gtx is offline
Last journal entry: Rear End Disassembly
I put a coat of paint on and i had some problems. Maybe you guys can help some. I figured out after I painted that I added too much hardener, it called for 8:2:1 paint:reducer:hardener and i put in 8:2:2. But, what happened is I painted the enamel and there are tons of "craters" in the paint. Could this be caused by too much hardener, or is it perhaps another story? I had the piping set up but caught no water. I had two back to back filters at the gun so i doubt there was any water. Might I also add that I put a heavy coat of paint on since it was on a flat surface so no running was an issue. Otherwise, it looks shiny and good but the craters don't work for me.
