Water pump bypass, vortec heads - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-17-2005, 04:57 PM
blndweasel's Avatar
paints everything flat black
Last journal entry: September 2005 - Current
I've been scouring over old posts all day, looking for any additional information that may explain a coolant leak in my SBC.
I'm running a 1970 3970010 block with SDPC vortec heads and a standard rotation milodon water pump.
The vortec heads do not have a provision for the water pump bypass circuit that comes from the passenger side of the water pump. the gallery in the engine block from the water pump bypass ends at the cylinder head.
It's okay to run with this setup, correct?
I'm just being paranoid at this point, I'm short on sleep and keep second guessing my setup.
thanks in advance
the blonde weasel
Old 06-17-2005, 05:03 PM
blndweasel's Avatar
Also, I'm running with a heater delete... do I need to install a nipple in the heater outlet on the water pump, and plumb this to the bypass inlet on the intake manifold?
I think I'm starting to go crazy...
tbw
Old 06-17-2005, 05:10 PM
DoubleVision's Avatar
Drill 3 small holes in the thermostat, about 1/16. this will act as your bypass.
water pump problem rakundig Engine 15 08-10-2007 09:15 AM
where's the water pump?? mikeweyman Engine 9 07-05-2004 05:34 AM
Water pump rotation question djenn Engine 6 03-07-2004 10:04 AM
power steering from long water pump to short water pump kellyem Suspension - Brakes - Steering 7 02-22-2004 07:22 PM
water pump heater hose conenction.... oldcarguy85 Engine 3 04-07-2002 09:34 AM
