Water pump casting numbers - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-04-2006, 05:46 PM
DaSouthWon's Avatar
I put up the tools against$300
How can I determine if my BBC has a long or short water pump? I checked the internet for casting number information but was unable to find anything. The casting number on the water pump is 10126716. Thanks for the help
Old 05-04-2006, 06:09 PM
Wiki Edits: 31
the neck that leads up to the pully is longer on a long pump, take it to napa or such, they could match it up.
Old 05-04-2006, 06:54 PM
GoneNova/406's Avatar
if you have a short pump but need a long one you can get the leg extensions or spacers from many places.jegs has them from moroso for $30.00.you may still have to use shims to align your pulleys though.
Old 05-04-2006, 10:43 PM
DaSouthWon's Avatar
I don't know if the kneck is longer or shorter because I don't have anything to compare it to. Is there any site that has water pump casting numbers? I checked mortec but no luck
Old 05-05-2006, 12:36 AM
techinspector1's Avatar
Wiki Edits: 326
BBC short pump 5 3/4" block to hub
BBC long pump 7 5/16" block to hub
Old 05-05-2006, 10:03 AM
DaSouthWon's Avatar
thanks tech inspector.
BBC Water pump Question JamesRS Engine 8 08-02-2007 01:56 PM
electric water pump for the street Z28cheverra General Rodding Tech 7 01-06-2005 08:51 AM
Water pump rotation question djenn Engine 6 03-07-2004 10:04 AM
Stock-type water pump concern... BarbWire Engine 3 07-25-2002 06:09 PM
water pump heater hose conenction.... oldcarguy85 Engine 3 04-07-2002 09:34 AM
