Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Water Pump Functionality
Old 08-15-2012, 08:51 AM
64Joker's Avatar
64Joker 64Joker is offline
64Joker
"Not under diving the pump"
Originally Posted by oldbogie View Post
I would suggest that overheating problems are better solved with not under diving the pump on street engines, and using a clean and properly sized radiator along with adequate fans and shroud to pull air over the entire core surface.
Bogie
What does "Not under diving the pump" mean?
