Water pump help - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-28-2010, 07:53 PM
Water pump help
I'm new to this site and hot rodding so this will be the first of a million questions. I have a 31 'A' 5-window coupe with a 327 small block. The motor sits low where the fan only cools the lower half of the radiator and I would like to have the fan more centered. I was told there is a water pump designed with water journals raised 2-3 inches, which better centers the fan on the radiator. I know I could easily go with an electric fan but I would rather stay with belt driven. Is anyone familiar with this type of water pump? Also, what is a good place/web-site to find a variety of headers designed with the 31' in mind? Thanks.
Old 03-28-2010, 08:04 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Sanderson is one place for rod pipes.
Old 03-29-2010, 07:54 AM
345 desoto's Avatar
Location: Skaneateles, NY Summer/Port St.Lucie, FL Winter
Try here...http://www.jalopyjournal.com/forum/s...d.php?t=357516
and here...http://www.dannysrods.com/engine_accessories.html
Old 03-29-2010, 12:14 PM
More water pump help
Thanks for the info guys. Do you or anyone you know have any experience with the 'Zip' raised water pump setup? I'm kind of anal about reliability. Any opinion on going with something like this or should I consider an electric setup (Keeping reliability in mind)? Thanks again.
Old 03-29-2010, 12:41 PM
327NUT's Avatar
"Deuce" a moderator on here uses the Zip water pump with obvious xlnt success. He should be along here before to long with some pics of his hot rod(s).
Chevy water pump, long and short of it. suprstock Hotrodding Basics 15 06-22-2015 07:58 AM
Ford 351 water pump question. el pollo Engine 18 01-25-2009 11:09 AM
351W Water pump application question RAW Engine 7 11-13-2006 04:24 PM
Which waterpump? Eagle1 Engine 5 08-06-2004 06:38 PM
water pump heater hose conenction.... oldcarguy85 Engine 3 04-07-2002 09:34 AM
