Water pump-pulley interference - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-19-2012, 03:03 AM
staleg's Avatar
Last journal entry: Home made gear stick
Got my new Weiand Action+ waterpump today, and the aluminum pulley interference with one of the heater hose outlets on the pump, so what do I do? Complain & return is not an option, as I live in Norway.
On the leaky Allstar pump, the samme pulley fit perfect.
Shim out the pulley? The alignment was perfect with the old pump, so I don't want to do that. Unless the pulley on the new pump is too far back, of course.
Carefully grind some off both the pump and the pulley? That's what I think will be best.
Other suggestions?
Old 12-19-2012, 05:28 AM
water pump
if you have a chev engine could you have gotten a short water pump in place of a long water pump.
What kind of vehicle are you talking about? Also what engine is in it? Post a picture if you can, it would make it easier to know what is happening.
Old 12-19-2012, 02:02 PM
staleg's Avatar
Hi. Sorry.
It's a Chevy small block with short water pump. The new pump is short, too.
I won't do anything more about it, until I have taken the old pump off. Then I can compare them on a flat surface and see in what way they differ.
One more question, while I'm at it: The old pump has 1 water outlet on top were I have put the heater hose. The other heater hose I have fastened on the intake.
My new pump has 2 "heater hose sized" outlets. What are No 2 for? Should I block off that one, or should I route both heater hoses to the water pump and block off the manifoil outlet instead?
Old 12-19-2012, 04:45 PM
Which outlet does the pulley interfere with the top or the side one. On the firewall you have two fittings going to the heater coil. The top hose 3/4 goes to the water pump. The bottom hose 5/8 goes to the intake on the left side of thermostat housing. Plug the inlet that is not being used on the water pump.
Old 12-19-2012, 06:09 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by staleg View Post
Hi. Sorry.
The hose from the front of the intake at the water crossover or thermostat housing goes to the heater core. It has pressure and the hot water. The return from the heater core goes into the water pump. Use the port that is easiest or doesn't interfere with anything and plug the other port.
Old 12-20-2012, 12:18 AM
staleg's Avatar
The pulley interfere with the side outlet, that I probably won't use.
Old 12-20-2012, 12:40 PM
I had the same problem on a new engine in my hot rod. Short water pump and interference with the pulley on the side heater hose boss. I was able to grind just enough off of the boss to clear the pulley.
Old 01-05-2013, 09:53 AM
staleg's Avatar
Problem solved.
Grinded some of the pump, and 1mm (1/25 inch) of the rear of the aluminum pulley.
chrome water pump pulley atichargr Engine 7 05-03-2009 07:39 PM
water pump pulley runn141 General Rodding Tech 2 07-25-2007 07:33 PM
wobbly water pump pulley vetteman Engine 10 01-07-2007 08:55 AM
Where to buy BB water pump pulley? goneguy Engine 3 11-14-2004 12:10 PM
Overdrive Water Pump Pulley SilverFox2 Engine 15 08-29-2003 09:03 AM
