In the summit catalog you will find the plates that rivet or bolt onto the back of the impeller to provide more area to propel water. If you want to take the pump apart(5-6 bolts to gain access to the impeller)and attach the plate you can make your self a high flow water pump. That's all there is to a generic water pump. some companies who charge really high prices for pumps actually mill the pump cover to do the same thing as the 5$ plates you can do yourself. Sometimes the larger companies will also install larger bearings as well. If you are a street runner than I gotta recomend the above.
