i know this sounds stupid but most water pumps ive seen that are belt driven ( oem belts and pullys ) allready move way more water than nescessary and usually need t. stat to slow the flow down so that the water stays in engine long enough to dissapate heat out of heads and cyls. the only time ive truly seen the need for any type of high flow w pump was either with underdrive pulleys or electric motor driven stuff and if you actually dont need the extra flow its just gona rob power, i know it seems petty but even 1 % of power waisted having to drive accessories or internal engine componets that are unnedded is just waisting power and most anything thats advertising 25% more output is usually gona need some sort of extra input to run it. just another view to add to the growing collection. see ya Mikey
