Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Water Pump Question
Old 08-22-2003, 09:12 PM
wheel-7 wheel-7 is offline
Hi Flow pumps
Hi K
I put a aluminum " Flow Kooler " water pump on my 53 Stude coupe. The coupe has a 351-W instead of the Cleveland as you have. It helped a good deal on cooling. The temp. drop was about 20 degrees. It weighs about six lbs. less then the stock cast iron unit I took off. I think it cost me about $ 80.00 from Summit ? Hope this helps
