Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Water Pump Question
Old 08-22-2003, 09:35 PM
brief madness brief madness is offline
New Member
Not quite a 351C, but I have a warmed over 302 which never ran over 190 degrees. I have a Crane roller cam, roller rockers, 600 Holley, full length headers, MSD ignition, etc. I use a stock water pump (which has a backing plate already installed) from Kragen, a four row radiator, 160 degree thermostat, 8 quart oil pan with high volume oil pump, flex fan, no fan clutch and no shroud. It has never run above 190 degrees, highway or stop and go in rush hour. Just something to think about.
