Water pump question... - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-13-2012, 03:13 PM
Does anyone know if they make a shorter Ford small block water pump and pulley set up? Im running into radiator clearance issues on my motor swap.
Old 01-13-2012, 03:57 PM
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
Shortie water pump, 2" shorter than stock....
http://www.snowwhiteltd.com/products.htm
Old 01-13-2012, 04:08 PM
Any idea what the pricing is on that?
Old 01-13-2012, 04:32 PM
Senior Curmudgeon
Wiki Edits: 326
call 'em
http://www.snowwhiteltd.com/contactus.htm
Old 01-14-2012, 06:49 AM
OMG what a pain in the *** this is...Why was Ford so stupid with their water pumps, timing covers and dampeners design? There is so much nonsens involved in just getting this right..I need to do the timing chain cover, possibly the damper or a spacer...FML!!! Ford stinks Now I know why I have always been a Chevy guy...
Old 01-16-2012, 12:18 PM
Some updated pictures of the motor mounts that I purchased and heavily modified to make the motor sit in the engine bay at a decent height. At first I was concerned about the clearance issues with the water pump to my radiator cause I could not move the motor back any further due to the double hump oil pan. I found a solution for that, a 1969 Mustang water pump with passenger side inlet which is shorter than stock, and a company called CFV Racing who makes the obsolete pulleys for the short water pump. this should give me 2-3" clearance, perfect to put in a mechanical fan...In the pictures are the long water pump, and you can see I have about 1"-1.5" of clearance if that, but the motor is rocked back a little cause there is no transmission hooked up to it.
The motor mounts the way I modified them, (cut about 2/3rds of them away and mounted upside down.) give the motor the perfect stance, but now Im just worried about hood clearance issues with the Trickflow intake...I would hate to do all this only to have to go with a Carb set up..PS dont mind the Blue intake, some idiot painted over the powedercoating...
Thanks guys for all the tips and help so far!!!
Old 02-07-2012, 11:04 PM
Here is another question, Now that I have the short water pump with passenger side inlet, what timing pointer do I use???
BBC Water pump Question JamesRS Engine 8 08-02-2007 01:56 PM
Water pump question arch Engine 9 05-02-2004 07:34 PM
SBC Water Pump Question? Jag Daddy Engine 0 03-29-2004 08:19 PM
power steering from long water pump to short water pump kellyem Suspension - Brakes - Steering 7 02-22-2004 07:22 PM
Water Pump Question Kaylah Engine 11 08-22-2003 09:35 PM
