Water Pump Rotation - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-07-2007, 06:19 PM
Water Pump Rotation
Ok, I've searched this forum and still am confused. When standing in front of the car looking at the engine. (Pre 86 Crate 350SBC with V pulleys), which direction does the water pump turn CW or CCW. Thanks in advance. George
Old 06-07-2007, 06:35 PM
GMC boogie's Avatar
That would be clockwise.
Old 06-07-2007, 06:49 PM
454 Rattler's Avatar
NEVER SATISFIED !!
GMC boogie is correct ! Hope that helped you out, George.
454 RATTLER
Old 06-07-2007, 07:12 PM
Sorry for being so stupid, I should have figured it out from the Crankshaft rotation. Thanks anyway guys. I'm sometimes not the brightest litebulb, but I am a quick learner. George
Old 06-07-2007, 09:30 PM
NEVER SATISFIED !!
No problem ,George. At least you asked an easy question. Those I can answer. GMC boogie was faster but I DID know the answer.
Remember, there are NO dumb questions, but there are dumb answers.
454 RATTLER
Old 06-07-2007, 10:20 PM
techinspector1's Avatar
Wiki Edits: 326
Serpentine belt systems turn the pump counter-clockwise.
Old 10-20-2008, 11:36 PM
New Member
I also am still Confused...
About 1999 I read an article about the Ford "short pump". I bought it but didn't use it so I put it on the shelf. Today I've built up a SBF in a track roadster with this pump using v-belts and it is overheating. I'm wondering if the pump might have been a reverse rotation type. I had disassembled it for powdercoating. I didn't elongate any holes but I might have pressed on another hub if I discovered the holes didn't match the w/p pulley....this part of the project was over 5 years ago so my memory isn't so good. I used Zoops pulleys and couldn't get the spacing right so I milled a spacer to bring the crank pulley forward about .3". This pump has a metal plate on the back. The timing cover the engine is using had originally served as the back side of the pump but the ports lined up and it sealed well. I also plugged the heater outlet. The temp goes way over 230 and then looses the 50/50 coolant past a 13# cap.
I'd can't tell from all the foregoing discussion if indeed it would be possible to have a reversed impeller in this pump. What to you guys think ?
BBC Water pump Question JamesRS Engine 8 08-02-2007 02:56 PM
The correct water pump?? Overdriv Engine 3 01-17-2007 09:21 PM
351W Water pump application question RAW Engine 7 11-13-2006 05:24 PM
BB Chevy Coolant Leak @ Water Pump leejoy Engine 3 07-04-2006 02:10 PM
water pump heater hose conenction.... oldcarguy85 Engine 3 04-07-2002 10:34 AM
