water pump type - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-01-2003, 05:10 AM
Post water pump type
I have an engine in my 1965 vette that is a 1980-85 GM block 350 cid (truck), this is based on the numbers stamped on the block.
Everything I read says that the water pump for that year and size engine would be a long water pump.But, talking to people who have seen it they say they **think** it looks like a short pump. Is there a deffinate way to tell, and if I get the number stamped on it would there be a web sight that anyone knows that could confirm it.I'm trying to pick a pulley set for it and I have to know in order to pick the right one. Also would either type pump both fit?
thanks
Old 03-01-2003, 05:48 AM
awsum34's Avatar
Post
If you can put 4 fingers between the pump and the timing chain cover. say about 2 1/2 inches it's a long pump.. If you can only put about 2 fingers in it's a short water pump.
Old 03-01-2003, 06:05 AM
Post
1965 Corvettes had a short pump.
This is a photo of a short pump.
[img]http://photo.starblvd.net/~DeuceRoadster/2-4-1.jpg?i=1041869852&pw=*3B943E60CAC1[/img]
Old 03-01-2003, 06:14 AM
awsum34's Avatar
Post
Deuce, Thanks, The pictures make it better to see than trying to explain with fingers.
Old 03-01-2003, 08:12 AM
New Member
Post
also if i am not mistaken, a long water pump measures exactly 7 inches from the base where it mounts to the flat part of the flange where the pulley mounts.
Old 03-02-2003, 05:11 AM
Post
Thanks guys for all your help. After looking at the pics it's definately a short pump.
