Don't know exactly what you are asking, but the short pumps were used on 68 and earlier and the long pumps on 69 and newer.
That is, except on Corvettes, they continued to use the short pump, because of space problems.
Ontario Rodders |
It depends on what the motor is going into, Use the short one if you clearance issues with the rad. There is a difference in the pulley's that determine the pump that is used also. they have different spacing between the two style's of pumps. Hope this helps you out. Perry.
Short and long pump have the same capacity................so it wont matter which you use. I feel that the long pump with the alternator on the passenger side head looks less cluttered. Only problem with that is that the 283 head is not tappped to accept the alternator stud.....you can get around that though.
Ontario Rodders |
Yeah Daddyo, Shouldn't have any problems with the right bracket with those heads. Perry.
| Aluminum Water pumps, what's their advantage? | Houman SS '70 | Engine | 9 | 04-26-2005 09:09 PM |
| bbc water pumps | 68chevelle_ss | Engine | 7 | 04-24-2004 04:17 AM |
| electric water pumps??? | classic_chevy_guy | Engine | 3 | 10-24-2003 10:09 PM |
| Milodon High Volume Water Pumps | Jag Daddy | Engine | 2 | 04-11-2003 06:15 AM |
| Need water pumps. | senor_limpio | Engine | 5 | 12-02-2002 08:59 PM |
