Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - water pumps
Thread: water pumps
Old 10-16-2006, 04:39 PM
cardaddyo's Avatar
cardaddyo cardaddyo is offline
always the hard way...
its for a 283 build-up that is almost complete,but wasnt sure if the pump mattered.i have the serp set-up for a 4.3,that will swap,but it requires a reverse rotation pump.i still have the original short style pump, and i want my mouse-house to be clean and uncluttered,that all but eliminates the serp set-up.what kind of flow (gph) should i look towards. its a 283 .60 over,flat-top 9.5:1 pistons,stock forged crank turned 10-10,recon.327 rods, comp 268 cam(prt# 12-242-2)(.477-.480 lift)vortec heads,valve job,all comp valvetrain,trick-flow full bodied alum. roller rockers,rpm air-gap intake,and a tinkered with 750 dp on top.electric is an option also,leaves only 2 pulleys and one belt!?? what do you guys think?
