water separators? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-10-2011, 08:19 AM
dirtracer8c's Avatar
water separators?
I'm painting my truck soon and need to buy a good water separator. My question is can I use something like a Devilbiss CT30 for my air tools as well? Or is this something that is only used for spraying? It seems costly to replace the filters. Also what is a good filter for home use? I do very little spraying in a year.
Jeff
Old 03-10-2011, 02:58 PM
302 Z28's Avatar
IMO the biggest improvement in water control is raising the delivery line to the highest point in your shop. Install a drain at the point where it starts to go up, then install a water separator and drain at your hose connection.
Vince
Old 03-10-2011, 08:09 PM
My set up
I have my compressor in the second story of the gargae. Then from there I drop one out of the ceiling to a hose reel. the second one goes down the wall and has a trap. That's where I would like to install the separator.
Jef
SBC Long water pump or short water pump? johnnnz Engine 28 08-21-2011 01:20 PM
Well water (iron in water) Automotive paint 1931 steve Body - Exterior 11 07-14-2005 09:29 AM
SBC short water pump vs long water pump and other questions Jag Daddy Engine 9 04-02-2004 09:29 AM
power steering from long water pump to short water pump kellyem Suspension - Brakes - Steering 7 02-22-2004 07:22 PM
Water in oil? Camaro2Fast4u Engine 9 03-21-2003 03:56 PM
