-   -   water in T350 (http://www.hotrodders.com/forum/water-t350-86211.html)
Dgas 04-06-2006 08:05 AM
water in T350
some got in the front and rear seals and busted off vent (replaced it since). probably less than 1/3 cup ,I soaked some (most) out through the dipstick hole, but I can see quite a few droplets now + then in various places, this is an orig. used tranny to use while i wait for a fresh one to get here , new F+R ,pan seals,filter etc.are installed. problem?
FASTCHEVY 04-06-2006 12:28 PM
Huh? So you haven't removed the pan? :confused:
Dgas 04-06-2006 01:10 PM
changed filter+ sealed it up B4 I sprayed er down, after I removed pan and wiped that out again, but still a few drops coming down .
Triaged 04-06-2006 02:24 PM
If you already drained and filled it once - run it for a short time (up to temp) and then change it again.
Crosley 04-06-2006 08:24 PM
one of the problems with water in a trans is the friction material will separate from the base metal
chrisflock 04-08-2006 10:14 AM
One of the problems with water in the transmission is that it turns the fluid into a new chemical that looks (and does not smell) like peanut butter. About the same consistency too!
Another problem is that when it gets about -10 or so, the water seperates from the trans fluid and freezes, and then when you fire it up, some part that is supposed to move/spin can't and your buddy Eric's T5 in his astro detonates like a hand grenade, and then he's too cheap to buy a new one, and he gets some used ones from some camaros and another astro and trys to put them together to form some hybrid, franken-worldclass astro T5, and you end up with parts all over his porch and he doesn't remember where they go or how to put it all back together, and he calls you to help him sort it out.
I'm ranting now.
Chris
Dgas 04-08-2006 10:26 AM
I have just about decided to just take one of my cores in and have it rebuilt ,this one only has to be to move the car in + out of the body shop building until the car is painted and i can change it back out again :( .
As to the T5 , don't blame eric for being cheap, around here they get 500 -900 smackers for a USED T5 + given the cost of a new one,I would'nt buy a new or used one myself, I just scrap those cars that have em if they are bad.
