water in T350 - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > Tech Help> Transmission - Rearend
Old 04-06-2006, 07:05 AM
Location: MN.land of 10 million mosquito ponds-alias D/Gas
water in T350
some got in the front and rear seals and busted off vent (replaced it since). probably less than 1/3 cup ,I soaked some (most) out through the dipstick hole, but I can see quite a few droplets now + then in various places, this is an orig. used tranny to use while i wait for a fresh one to get here , new F+R ,pan seals,filter etc.are installed. problem?
    Advertisement
Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 04-06-2006, 11:28 AM
FASTCHEVY's Avatar
RatRod B4 RatRods were Cool
Huh? So you haven't removed the pan?
Old 04-06-2006, 12:10 PM
changed filter+ sealed it up B4 I sprayed er down, after I removed pan and wiped that out again, but still a few drops coming down .
Old 04-06-2006, 01:24 PM
Last wiki edit: Vacuum brake bleeder set up
If you already drained and filled it once - run it for a short time (up to temp) and then change it again.
Old 04-06-2006, 07:24 PM
Crosley's Avatar
Global Moderator
Last wiki edit: T-350 rebuild tech
Last journal entry: 1962 Morris Minor 1000
Wiki Edits: 1659
one of the problems with water in a trans is the friction material will separate from the base metal
Dont worry how old you are... it is the mileage on your body that adds up.
Old 04-08-2006, 09:14 AM
chrisflock's Avatar
Last journal entry: A quick trip
One of the problems with water in the transmission is that it turns the fluid into a new chemical that looks (and does not smell) like peanut butter. About the same consistency too!
Another problem is that when it gets about -10 or so, the water seperates from the trans fluid and freezes, and then when you fire it up, some part that is supposed to move/spin can't and your buddy Eric's T5 in his astro detonates like a hand grenade, and then he's too cheap to buy a new one, and he gets some used ones from some camaros and another astro and trys to put them together to form some hybrid, franken-worldclass astro T5, and you end up with parts all over his porch and he doesn't remember where they go or how to put it all back together, and he calls you to help him sort it out.
I'm ranting now.
Chris
Old 04-08-2006, 09:26 AM
I have just about decided to just take one of my cores in and have it rebuilt ,this one only has to be to move the car in + out of the body shop building until the car is painted and i can change it back out again .
As to the T5 , don't blame eric for being cheap, around here they get 500 -900 smackers for a USED T5 + given the cost of a new one,I would'nt buy a new or used one myself, I just scrap those cars that have em if they are bad.
Recent Transmission - Rearend posts with photos
Quick Reply
Message:
Options
Register Now
In order to be able to post messages on the Hot Rod Forum : Hotrodders Bulletin Board forums, you must first register.
Please enter your desired user name (usually not your first and last name), your email address and other required details in the form below.
User Name:
Please enter a password for your user account. Note that passwords are case-sensitive.
Password:
Confirm Password:
Email Address
Please enter a valid email address for yourself.
Email Address:
Insurance
Please select your insurance company (Optional)
Log-in
Human Verification
In order to verify that you are a human and not a spam bot, please enter the answer into the following box below based on the instructions contained in the graphic.
You may post new threads
You may post replies
tranny cooler spokesc Hotrodding Basics 22 12-23-2005 10:49 AM
Well water (iron in water) Automotive paint 1931 steve Body - Exterior 11 07-14-2005 09:29 AM
Water in Oil Update... TurboS10 Engine 8 06-27-2005 06:55 PM
Water in Engine billg_69gmc Engine 1 08-24-2004 09:14 PM
water pump heater hose conenction.... oldcarguy85 Engine 3 04-07-2002 09:34 AM
