water from tailpipes - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-09-2004, 10:30 AM
astrops's Avatar
every time my car idles, i can see what looks like little dropplets of water spraying out of the tailpipes. Anyone have any idea what this might be.
Old 04-09-2004, 10:32 AM
Wiki Edits: 49
Its water. The heat from your exhaust causes some of the moisture in the air to condense. It's perfectly normal.
Centerline
Old 04-09-2004, 11:18 AM
deuce_454's Avatar
not quite, it is normal, but heat doesnt cause water to condense...
the water comes from burning a hydrocarbon fuel, (gasolene) when the carbon C and hydrogen H in the gasolene reacts with oxygen O2 it forms H2O water and carbonduoxide CO2 (other reactions also takes place but this is the main energy releasing reaction) when the exhaust system is not yet heated by extended running the water (in the form steam) condenses on the inside of the exhaust tubing and eventually drip out through the tailpipe
contensation will occur whenever a surface is colder than the dewpoint of the ambient atmosphere, so centerline, the next time your Cold beer becomes wet on the outside on a hot and humid day, its not because the bottle is leaking, its the vater vapour condensating on the COLD bottle
(no offence intended centerline, but i couldnt help it... )
Old 04-10-2004, 02:31 AM
It means you need to take it out & floor it more often so your muffler won't rust out.
Old 04-10-2004, 07:29 AM
Wiki Edits: 49
No offense taken. You simply stated things in more technical terms.
Centerline
Old 04-10-2004, 10:38 AM
4 Jaw Chick's Avatar
Distracted by shiny objects
Wow, You guys sure have a way with words. I always knew what it was, and I knew it was normal, but never have I seen it expressed with such.....eloquence.....BRAVO!!!! Gee, I guess I better take the SHO out for high speed cruise and blow dem pipes out.
Chickie.
