water temp. of a pontiac 455 - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-14-2012, 09:47 PM
The car is a 76 trans am with a 455. As of right now the water temp. gauge on the inside of my car reads 240. Is this to hot? what temp should it be running at? what can i do to keep it cooler? This is my first car so i really dont know what it should be at, thanks.
Old 08-14-2012, 11:44 PM
WDCreech's Avatar
Grumpy Old Goat Herder
240 is definatly too warm. As long as you don't boil the water out, your engine should be okay, but I think you have a problem in your cooling system. Was the engine recently rebuilt and if so, were the devider plates installed correctly in the water pump? Tell us about the engine and we'll go from there.
Bill
Old 08-14-2012, 11:56 PM
I think it has been, the engines out of a 74 thats really all i know because i just researched the block numbers. How would i know if the divider plates were installed corectly in the water pump? like i said i dont know much, this is my first car, i just turned 18 and ive done all the work myself, learning as i go. thank you for your help so far.
Old 08-15-2012, 04:38 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Does it always run that temp or does it run cooler (or hotter) around town or on the open road? This can help isolate the problem as being a lack of airflow or coolant flow, etc.
First be sure the temp gauge is reading correctly. Use a temporary mechanical gauge to check it.
Be sure the thermostat is working as it should. If you have a clutch fan, check it for correct operation as well. Be sure there's no belt slippage- sometimes you won't hear the belt squeal. If you have a flex fan, they can cool poorly. You also need a shroud that fits the fan assembly.
Here is some info on the divider plate that could help you. No rust holes allowed!
Also be sure the sleeves/grommets are in place correctly.
You should check the ignition timing to be sure it's not retarded. This isn't usually a problem, given the low compression of the stiock Pontiac engines from the smog years, but it's still worth checking.
water temp tylerrosario1234 Engine 3 07-26-2011 12:27 PM
buick 455 and pontiac 455 valve covers rooster88 Engine 2 07-14-2011 07:50 PM
Pontiac 455 Water Pump Install Houston54 Engine 4 07-25-2008 01:32 PM
pontiac 455 or rocket 455 Robinson Robin Engine 10 02-03-2005 09:26 PM
Olds 455 vs. Pontiac 455? bildo95 Engine 3 06-27-2003 04:53 PM
