Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Waterborne paint
Old 09-11-2012, 04:28 AM
milo's Avatar
milo milo is offline
point on positive
I've settled in with PPG's Envirobase and really like the matches. Hope to here how the turbine works and think it might be better in some instances then a regular air type gun for wateborne .. the air can be heated with that right?
The trick with waterborne is to get the first coat on wet without a run and then dust in subsequent dust/control coats..
Waterborne likes air movement (just a little) and non humid conditions,, here's a clip where the part is moved through the air and fans the part that is in a stand
