Waterpump or fan? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 01-21-2008, 08:21 PM
Everything is HAMMER!
Thanks for the advice guys, i'm going to get a 16" puller fan and do a full sheetmetal radiator shroud with the fan mounted in the center of it.
As for cruising temp it only heats up when it's held at about 70 plus behind traffic(ie highway) so im convinced its an airflow issue. So the factory style air dam will be installed, it seems that is the only way to keep these cars(thirdgen camaros) cool on the highway.
Once again this radiator provided more than sufficient cooling for a severely beat on monte carlo, so i highly doubt that it's plugged. But i will see if it is plugged once the e-fan and airdam are installed and it still doesn't provide more than adequate cooling, that is if worse comes to worst.
building a fan shroud - need help 32Tudor Hotrodding Basics 30 07-03-2008 09:01 PM
Electric cooling fan Z-Money Pit Engine 1 08-29-2006 08:27 PM
Need advice on a good electric fan set up. Streetmaster Engine 13 01-07-2006 02:37 PM
? about an electric fan for PU. Streetmaster Engine 8 08-20-2005 10:14 PM
Fan Clutch Bad After 400 miles? Ghetto Jet Engine 10 04-02-2005 09:21 PM
