Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Waterpump or fan?
Old 01-20-2008, 04:03 PM
DoubleVision's Avatar
DoubleVision DoubleVision is offline
For starters a half shroud isnt doing it much good, for starters I would inspect the radiator fins and the a/c condensor, its quite possible over the years the fins are so clogged with debris they will need a good cleaning with a high pressure washer set on fan spray. Next install a complete fan shroud.
Since you didnt give a lot of details on your engine, I know you converted it to a 350 as these cars didnt come with them, but during the conversion what carb and distributor did you use? Next is the coolant resivoir still functional?
