Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Waterpump or fan?
Old 01-20-2008, 05:45 PM
stroker_SS stroker_SS is offline
Everything is HAMMER!
The heater lines are plugged via short hose and plug. Don't know if that will effect the cooling system at all, and if it does, what do you suggest i do, i don't even have a heater box, so running hoses to the core would be a waste of hose, unless it will help keep it cool.
my plans are to finish the shroud,well complete the circle. refill the cooling system according to the service manual. and install the air dam, where would be the best place to find an air dam for my car, i already called the parts stores and they don't have them, maybe a dealership part?
if the flex fan doesn't do the trick for cooling it at idle, what kind of fan do you guys suggest.stock style perhaps?
