Waterpump swap question - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-28-2010, 09:07 PM
Zeeb's Avatar
Water pump swap question
I have a 1990 "old school" 350ci SBC that originally came with the long style water pump. In its new home, a Mazda RX7, we have a clearance problem, pump shaft to radiator, making it impossible to use the puller fan I would like to install. If I could bolt up a short style pump, the kind used on earlier blocks, problem solved. The only accessory besides the water pump is an alternator, which is mid-mounted and on its way to low-mount due to hood clearance issues. So I'll just buy an alternator low-mount for a short WP. Will the short style pump fit my block?? Thanks!
Old 06-28-2010, 09:52 PM
ericnova72's Avatar
More for Less Racer
Yes, it will bolt up. common mod for most street rods with small engine bays.
Old 06-28-2010, 11:35 PM
Silverback's Avatar
Boost Retard
sure... if you still have the '90 water pump on it then the short pump will rotate in the opposite direction.
R&P Swap Question jpd37 Transmission - Rearend 1 12-15-2009 11:04 AM
96 t-bird engine swap question hddave1 Hotrodding Basics 4 12-08-2009 12:58 AM
350 head swap question followme21 Engine 1 09-11-2009 10:16 AM
200-4R swap question? zbhover Transmission - Rearend 3 07-26-2009 06:00 PM
Attention ford guys, 5.0L swap question. enginejr Engine 1 04-10-2008 08:51 PM
