Watts Linkage - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 01-17-2005, 03:39 PM
BillyShope's Avatar
Philippines Cowboy
Last journal entry: THE TRACTION DYNO
You can control camber changes, over absurdly large wheel travels, by mounting the inner pivot for one of the arms to a "rocker arm" which is controlled by a link to the other arm, but this is more suitable for off road trucks than Formula One cars. Back when the F1 cars were using more wing, they even considered eliminating the suspension entirely.
(What are we doing talking about this sort of thing on a hotrodding board?)
  #17 (permalink)
Old 01-18-2005, 07:18 AM
Phat's Avatar
Toy builder
Sometimes body roll is a good tuning tool but thats oval racing dont want to hijack this thread.
  #18 (permalink)
Old 01-18-2005, 08:19 AM
I've been reading a book on suspensions. IMO, you should REALLY understand the function of either before going foward. On a WATTS linkage, you should find the role center of the rear axle and have pivot point of the WATTS match. A Panhard bar also has it's unique characteristics. For instance when the body rolls in a turn the Panhard bar exerts a lateral force on the body. Depending on which side it's mounted to the body, it'll either plant or lift that side of the axle. In some situations, it can actually lift the wheel you really need the weight on.
Whith a Panhard bar you need to be mindful of front spring bushings. you need to have compliancy or things will bind.
  #19 (permalink)
Old 01-18-2005, 01:37 PM
Rich_Long's Avatar
Old Mustangs are to hotrods!
Last journal entry: 68 Mustang Fb
panhard/watts
My 03 Marauder has a watts setup on it from the factory and it is a wonderful thing!
On my Mustang project, i was thinking of a using a panhard , but when I figured out that the Traction master style bars I'm putting on ( very heavy "copies" of them) would do a fine job of keeping things straight, I decided not to.
What I need is a rear sway bar to fit in between my narrower frame rails.
Can someione help me out with that?
  #20 (permalink)
Old 01-19-2005, 06:05 AM
BillyShope's Avatar
Philippines Cowboy
I agree that hotrodders should have an understanding of suspension function, but there are books and there are books. Just because someone has taken a lot of pictures of the undersides of cars and published a book doesn't mean the book is of any value.
But, good books aren't cheap! Why not buy the book that many automotive engineers had to buy as they went to school? Race Car Vehicle Dynamics, by William and Douglas Milliken, is used as a textbook in many engineering colleges around the world. It's published by the SAE and is available through the SAE or from amazon.com. It's a bit cheaper through amazon, but, in either case, you won't have much change left from a century note. It's not something you can read as you watch "Gilligan's Island," but the value is proportional to the effort you expend.
Your comments on the Panhard reflect the thinking of some oval racers (mentioned in an earlier post). It's the vertical force component (when the bar is mounted at an angle), however, which provides the loading and...and this is the important part...it only affects loading as the car sets up for the corner (while the chassis is being accelerated either up or down). In other words, once the car is settled into the corner, it doesn't matter where and how the Panhard is located (so long as the roll center height is not affected). Personally, I believe there are better ways to achieve the same oval track performance, but they don't involve the Panhard bar, which is the subject here.
So, again, if the Panhard is as long as possible and mounted horizontal, you don't need to worry about the complications of a Watts linkage.
  #21 (permalink)
Old 01-21-2005, 08:36 AM
johnsongrass1's Avatar
Race it, Don't rice it!
Billy Shope:
Let's not forget what lateral locating device(s) on a dirt track isn't the same as to asphalt. In dirt track racing, The lateral lenght and mounting points in relation to moment arms change with chassis movement. The lateral locating device is never at rest. The car is never settled in a corner because of dirt is forever changing. You can go from slick to tacky dirt in two feet!
I'm not trying to argue with you, For I am not a chassis man at all, Nor do I have the experiance you do. However, I still think it's unfair to say the the lateral locating device has no affect once the car as found a set.
  #22 (permalink)
Old 01-21-2005, 11:36 AM
BillyShope's Avatar
Philippines Cowboy
Oh, I'll definitely agree there's an effect when there is axle housing motion relative to the chassis while the car is in the middle of the corner. Didn't mean to imply otherwise. It's my opinion, however, that this is not a good thing and that it's better to mount the bar horizontal and use other "tricks" for chassis tuning.
