Watts linkage in competition car - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-05-2006, 11:15 PM
1300
ehhh...Any reason to use above mentioned rear suspension in competition car?
(bad saying,but I hope,you understood,what I want to say.)
Old 07-06-2006, 07:27 AM
BillyShope's Avatar
Philippines Cowboy
Last journal entry: THE TRACTION DYNO
If you mean instead of a Panhard, the short answer is "no." The lateral motion allowed by a Panhard of reasonable length is inconsequential. You'd be hard pressed to find more than a handful using a Watts, to locate a beam axle laterally, in any of the world's competition divisions. (An exception might be found in certain "off road" classes, where suspension travel is an order of magnitude greater than that found in other competition classes.)
I suppose I should mention that there are some cars (mostly dirt track) that use a short, angled Panhard to achieve a dynamic loading as the car enters a turn. Personally, I believe this creates more problems than it solves, but I realize there are those who would strongly disagree.
Old 07-06-2006, 02:22 PM
Panhard bar length
Hi billy
What do you consider a reasonable length for a panhard bar?
I'm building a 57 pick up with a 4 link in it. Its set up for a panhard bar that will be 22.5 inches long. My other choices are to fab a new bracket and get it to 25.5 inches or go with a diagonal link.
Thanks for any info.
Kim
Old 07-06-2006, 06:22 PM
BillyShope's Avatar
Philippines Cowboy
Well, if you start with a 22.5 inch bar horizontal, 2 inches of jounce results in a transverse travel of less than a tenth of an inch. I'd consider that quite inconsequential.
Old 07-06-2006, 07:13 PM
Thanks Billy
Kim
Old 07-06-2006, 11:24 PM
1300
OK,thanks for assistance
1985 LTD 302 V8 Cheap begginer project car 1stPROJECTcar Engine 5 05-27-2011 04:18 PM
Buyer Beware................... poncho62 Hotrodders' Lounge 10 05-19-2005 10:40 PM
Watts Linkage ripper Suspension - Brakes - Steering 21 01-21-2005 12:36 PM
