waved plate - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-15-2004, 08:19 PM
BigBlock69's Avatar
New Member
waved plate
My question is about the waved steel plates. What is the purpose of the waved plate in the clutch packs? Can the waved plate be replaced with a steel followed by a friction or is the waved plate necessary? I want my 400 to shift as hard as possible and have purchased a cheetah turbo action reverese pattern manual valve body and a b&m master overhaul kit. I have a haynes manual for the 400. I want to be sure on the clutch packs before reassembly. I know transmission work should probably be left to the pros but I want to do it myself and have a hard shifting 400 or learn from my mistakes. Any advice on clutch pack setup would be appreciated. Thanks
Old 04-16-2004, 05:07 AM
airworld2's Avatar
steel plate
it used to cushion clutch apply feel (soft engagement)
before today I couldn't spell mechanic now I are one
if you touch a transmission here that makes you a pro (not)
haven't you heard its voo-doo, and black magic
