Wax and grease remover on bare ABS plastic, what now? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-24-2006, 10:59 AM
GMW GMW is offline
I accidently got some wax and grease remover on some bare ABS plastic that I just sanded all the old paint off with 80 grit. The ABS turned a greenish color and its really slick. Almost like a wet oily feel??? I tried hitting it with 80 grit again and it just slides around, doesn't cut in. What can I do to get this back to the way it was before I got the wax and grease remover on it?
Thanks
Merry Christmas!
Old 12-24-2006, 11:29 AM
BarryK's Avatar
Abs should not have done this but that is the main problem today is a plastic marked ABS or say PP may no longer be a true copy.
I read not to long ago that there were over 120 different versions call PP and way more for TPO and TEO climbing fast.
Try this mix about 50/50 alcohol (rubbing) and warm water and if you have around the house a slug if ammonia 1-3% is all by volume.
Wipe a spot and dry with a clean rag after it sets for 30 seconds, if there is an improvement in that spot than do the whole panel a few times or as long as it keeps getting better.
If it works when you are done do not coat the panel for a few hours to let all solvents out.
Hopefully it will work but try a small spot first.
Old 12-25-2006, 05:00 PM
GMW GMW is offline
OK. I screwed up. The piece in question is the front facia and its made out of Polypropylene. It has >PP< stamped on it.
The area in question still hasn't "dried out" enough for the sandpaper to actually cut again yet.
I haven't tried your suggestion yet Barry. Should I do something different for >PP<?
Greg
Old 12-25-2006, 05:11 PM
BarryK's Avatar
Try the mix on a spot. Should draw it out.
Leave out the ammonia.
Old 12-25-2006, 06:24 PM
mrcleanr6's Avatar
thats strange. pp should be a very chemical resistant plastic. usually you should be able to wipe it down with acetone directly and not have it bite into it. none of that matters though at this point since you have the problem. try barry's recomendation, if that doesn't do it put a little heat on it for a while. dont get it real hot. maybe like a halogen work lamp about 8 - 12 inches away. get it good and warm for a couple few hours then let cool down and see what its like.
Old 12-26-2006, 02:44 PM
I agree with Jim, Polypropylene shouldn't absorb anything out of Wax and Grease remover. The alchol trick Barry suggested should help dry it back out. Or time and heat like Jim says. When you do get it cleaned be sure to use an adhesion promoter designed for PP before you apply any coatings. PP can be one of the toughest plastics to paint, sometimes waving an open flame over the bare plastic for a little while before applying the adhesion promoter helps a lot. It's a greasy plastic but it'll take paint if prepped properly.
what else in in wax and grease remover besides mineral spirits? Dubz Body - Exterior 47 06-19-2010 01:09 PM
Glass cleaner after wax and grease remover? wreckedGTI Body - Exterior 20 06-17-2007 06:21 PM
Great tool, the Wax and Grease sprayer. MARTINSR Body - Exterior 13 12-19-2006 06:08 PM
wax and grease remover adrock430 Body - Exterior 14 07-30-2006 01:18 PM
wax and grease remover - non waterborne bad? pigman Body - Exterior 12 08-30-2005 07:57 AM
