Wax&Grease Remover on Fiberglass - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-26-2005, 05:26 PM
T7SuperBee's Avatar
Hey Guys!
I'm a paint and body newbie, but I'm getting ready to start prepping my '69 Super Bee's fiberglass hood for paint.
I picked up some wax & grease remover (proform) today to use to wipe the hood down beofe and after I sand it. The top of th hood is gel coated.
Anyway, the wax & grease remover says on the container... "THIS PRODUCT IS NOT RECOMMENDED FOR USE ON PLASTIC OR FIBREGLASS".. I notice this after I buy it of course!
Now, is this warning against using it on bare fiberglass? Is it safe to use these types of products on gel coat?
If I can't use the cleaner, how do I clean the hood before and after sanding?
Thanks guys!
Old 03-26-2005, 06:00 PM
mrcleanr6's Avatar
its fine on gelcoat. i would wipe with it first to remove any mold release but after sanding use acetone.
Old 03-26-2005, 06:30 PM
302 Z28's Avatar
Also give it a good wash down with some dishwashing detergent to remove any trace of grease or oil. Dry it then use the wax and grease remove to wipe it down real good. PPG DX330 is a good paint prep solvent.
Vince
Old 03-26-2005, 07:36 PM
mrcleanr6's Avatar
actually yes...i forgot to mention that. usually when i pull parts from a mold and prep it for paint i will first hit it with wax/grease then wash it with dawn and water, sand then wipe with acetone or wax/grease again.
Old 03-26-2005, 07:37 PM
T7SuperBee's Avatar
Hey Guys!
Thanks for the tips!
So:
1. wash with detergent and water
2. wash with wax & grease remover
3. Sand surface.
4. wash with detergent and water
5. Paint.
Should I wash it w/ the wax & grease remover after step 4, or before step 4, or not at all after sanding?
At least it's going to be a while before I can paint the hood here... its still hovering around the freezing point. Gives me time to ask questions though!
Thanks again guys!
Old 03-26-2005, 07:56 PM
The warning from the manufacture should not be taken lightly however. The reason for the warning is some absorbtion of the surface cleaner can occur. If it is a real slow evaporating cleaner like the PPG DX330 (very slow) it can stay trapped in the glass VERY easy. After wiping dry very well, let all cleaner flash off well before you seal it with primer, paint or what ever.
Old 03-27-2005, 05:27 AM
theHIGHLANDER's Avatar
Here's my way of new f'glass prep
1. hot soapy water and a scrub brush, rinse real well
2. wipe down with DX105 or denatured alcohol on gel coated areas only
3. allow lots of dry time so alcohol can help move water out of pores
4. sand and repair as needed (yes, they all need somethin!)
5. wash with milder version of hot soapy water and let dry
6. prime and surface for paint.
The biggest painindeazz 'bout glass is those friggen fisheyes and pinholes. The pinholes will allow solvent in. Trust me, there's pinholes in the 'glass. Good luck with it. You can use that solvent on lots of stuff, like gas stains on your alum intake, so ya didn't waste no dough by buyin it.
Old 03-27-2005, 06:27 AM
Probably the manufactures legal disclaimer since rubbing on fiberglass can create static electricity, might creat a spark.......... flameable wax and grease remover... could be a major problem.
Old 03-27-2005, 07:25 AM
BarryK's Avatar
Bingo!!
If this ever happens to you, you better hope your heart is in good condition!
I saw it happen once at a Frieghtliner dealer, the painter was on a ladder wiping the truck down with wax and grease remover in mid summer and all of a sudden everything went up in flames.
Old 03-27-2005, 08:41 AM
Never thought of that!
Old 03-27-2005, 09:47 AM
BarryK's Avatar
It was something! I was standing by his ladder talking to him and after wards he said I felt a shock. (static) and it was a flash flame and out in 10 seconds.
I had herd of this before with trucks but never seen it.
Old 03-27-2005, 10:24 AM
T7SuperBee's Avatar
Hey Guys!
Wow, Im definitely glad I asked the question! Definitely didn't think anything dangerous could happen from using the product, just though it could lead to a poor prep job!
I'll definitely just use soap & water, and some acetone or alcohol instead of the wax & grease remover... its definitely not worth risking having something blow up in my face!
Could a person use some kind of a synthetic applicator that doesn't cause static somehow?
Is there no danger with the alcohol or acetone of catching fire, or do they just evaporate too quickly?
Thanks guys!
Old 03-27-2005, 03:15 PM
you could use an anti-static cleaner/degreaser.
Old 03-27-2005, 06:03 PM
mrcleanr6's Avatar
Originally Posted by BarryK
Bingo!!
hey barry thats some crazy s&%$. never hear of that.
superbee: acetone is an excellent surface claener for fiberglass or gelcoat. when doing any kind of fiberglass repair you always clean with acetone before repairing.
Yet another question about bonding fiberglass to metal Psionic Body - Exterior 41 10-20-2013 06:56 PM
34 ford 3 window coupe fiberglass body jaxhome Introduce Yourself 2 09-23-2006 09:45 PM
How Do You Make Things With Fiberglass? Silentlion_69 Body - Exterior 11 01-01-2006 08:05 AM
Fiberglass help for novice tyman00 Body - Exterior 1 10-20-2004 12:36 AM
Some quick fiberglass questions... 94max Interior 5 06-30-2003 04:21 AM
