Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Wax and grease remover = mineral spirits?
  #25 (permalink)
Old 03-13-2013, 07:44 PM
Old Fool's Avatar
Old Fool Old Fool is offline
One thing I have noticed is that a panel needs to be cleaned with solvent based w&g, then cleaned with water based w&g. There are contaminants that each will remove faster easier better than the other, or so that is how it appears to this old fart.
A good washing with Dawn, then a wipe down with a solvent base. When ready for paint I wipe it down once more with water borne. Might just be me, but the vapors from the isopropyl alcohol give me a head ache if I don't wear a respirator when using the waterborne.
Mitmak, you can save a few more dollars if you buy paint thinner instead of Mineral Spirits, its the same stuff. Get it in 5 gallon cans at Parker paint and save a few more dollars per gallon.
Great degreaser for use in your parts washing tank.
