Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Wax and grease remover = mineral spirits?
  #33 (permalink)
Old 03-14-2013, 06:31 PM
tech69 tech69 is offline
put up or shut up
Originally Posted by BarryK View Post
I understand what you are saying and sad part is if you do ask as lot of times will not know themselves, the training is getting worse and worse.
Buy the way a good grade water-wax and grease remover, used in the right area can be anywhere from 2-8 times better then solvent BUT must be the right one made for the job you are doing.
yeah, there's still some ignorance in regards to the usage I'm assuming and it's like we expect the same out of the water borne as solvent for every application. You'd know way more than I would on the subject. Far as I know we're probably using the wrong kind of whatever reason.
