Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Wax removal from textured trim plastic
Old 04-17-2010, 05:49 AM
red65mustang red65mustang is offline
I agree with cobalt and use 409 first specifically to determine what solvent type direction to try next if I don't know what is on there...
(it does no harm to most surfaces so it is a safe start point)
scrub with a Q-tip,,,if OK then spray soak a area with 409 and spray soak a paper towel and press/lay that on the area...
let it sit for an hour plus and then try a scrub brush with more 409...
do you know which Maguirs wax is on there???
many products (like Nu-Finish) are not "wax" at all....
you need something with the original carrier/liquid chemicals to "re-disolve" some of those....
if you know what it was (and maybe still have some?) re-apply it to re-disolve the residue and use a scrub brush with 409/water rinse to get it all off while still damp...
