Waxing acrylic paint help!!!! - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-02-2006, 01:59 PM
hello i painted my 1955 pontiac with acrylic enamel Candy apple red i used hardener but no clearcoat. The paint looks GREAT but i decieded to wax it. i bought maguires carbula wax i wanted to test it on the trunk so i rubbed it on and when i rubbed it off i go got quite a bit of paint on the towl and it doesnt look as good as i thought it would. i was ondering what type of wax i should use. Thank you.
Old 11-02-2006, 02:07 PM
That wax should work just fine, how old is the paint? what brand is the paint?
Old 11-03-2006, 04:43 AM
Waxing Laquer
Because the pigments of the paint are exposed with a single stage paint, it is only natural that you will get paint on your pad or towel, nothing to worry about there.
In fact, that is how you can tell if a paint is single stage or base-coat/clear-coat.
Any good wax or better, paint sealant will work on your paint be it single stage or two stage.
KEY, however, is that you should not wax or seal a new paint for 60 to 90 to allow the solvents in the paint to completely evaporate. Waxing or sealing too soon can cause solvent popping.
Regards
Bud Abraham
DETAIL PLUS SYSTEMS
Cost of paint Job - complete do it your self job at home Warrant Body - Exterior 74 07-13-2006 09:31 PM
Removing orange peel from acrylic paint - what do I do? Mad Maggot Body - Exterior 2 02-20-2006 10:53 AM
easy paint job info needed pjd Body - Exterior 1 08-09-2005 10:30 AM
Looking to paint my car with OEM quality finish. Have some Questions Gro Harlem Body - Exterior 12 01-15-2005 06:31 AM
What is Modified Acrylic Enamel paint? unioncreek Body - Exterior 3 06-13-2004 04:15 PM
