Way to adapt speedometer after changing from 3.73 to 4.56 - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-05-2011, 07:13 PM
I have an 85 Monte Carlo SS with a 200r4 and a factory 3.73 7.5 rear. With the 327 I have for motor I want to go to a 4.56 rear. What I'm wondering is there an adapter or something that I can make the speedometer be accurate with the 4.56 or should I find one of those radar activated speed signs that the cops like to put out and memorize where the tach is at the speeds I care about. Its nice to know these things when the radar detector is lighting up. The car has an autometer sport comp speedo if that matters at all.
Old 10-05-2011, 07:22 PM
Last wiki edit: Wiring diagram 1953 Chevrolet
Last journal entry: Spare Tire Dent Removal
Wiki Edits: 647
Just go in to your local Chevy dealer, tell them what transmission you have, the existing gear ratio and the proposed gear ratio and they will sell you a new plastic gear that fits in the transmission that connects to the speedo cable. Just that simple!
Old 10-05-2011, 07:28 PM
Thanks I really do appreciate the advise I get here.
Old 10-05-2011, 07:45 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
GM dealer may not have any 200-4r speed-O parts.
Look here this page , down about 3/4 towards the bottom the page is speed-O parts - gears
Old 10-06-2011, 02:34 AM
SSedan64's Avatar
2004R gears are getting scarce. May have to use a Ratio Adapter if you can't get the gears needed,
http://www.transmissioncenter.net/sp...n_______va.htm
Gears:
http://www.transmissioncenter.net/sp...____va.htm#200
http://www.tciauto.com/tc/transmissi...al-motors.html
Ratio Adapter:
http://www.transmissioncenter.net/sp..._____va.htm#gm ratio adapter
Help me adapt these air cleaners. HemmiGremmie General Rodding Tech 2 02-02-2009 07:04 AM
Can I Adapt My Buffer as a Scrubber? KarKen Body - Exterior 8 09-03-2004 08:55 PM
How To Fix Speedometer After Changing Gear Ratio 70SPORT Transmission - Rearend 11 07-21-2004 06:54 AM
adapt 94 IFS onto 66 el camino Echofive Suspension - Brakes - Steering 5 05-21-2004 10:21 AM
Need to adapt to elec speedo Jason Transmission - Rearend 4 07-09-2003 06:27 PM
