Way to check the rear end gear ratio........... - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-18-2007, 08:24 AM
My dad told me a way he has checked rear end ratios - put the rear of the car on jackstands, put it in neutral, mark the tire and driveshaft. Then watch the driveshaft while making 1 full rotation of the tire. I did this, and my driveshaft went around 1.7 times (couldn't be a 1.7 rear end......) Am I missing something? Am I supposed to multiply that number by 2 (would make a 3.42, makes more sense). Please let me know....
Old 06-18-2007, 10:22 AM
crash70rs's Avatar
Last journal entry: Going Slow.. and steady?
That method should get you close. You may need to have someone hold the other tire as well.
Old 06-18-2007, 11:13 AM
F&J F&J is offline
Last journal entry: 32 Ford cabriolet conversion/windshield
Posi ii one turn of the wheel.
Non posi "open rear" is: Leave one tire on the ground, rotate the other with chalk marks on driveshaft & tire. Turn the wheel 2 turns. Count the turns on driveshaft.
Old 06-19-2007, 12:51 AM
If you checked with both wheels off the ground, the wheel on the far side might have turned while you couldn't see it, and thrown your result off. Do it like F&J said.
Your dad's way is correct for a posi rear end.
Old 06-19-2007, 08:25 AM
BillyShope's Avatar
Philippines Cowboy
Last journal entry: THE TRACTION DYNO
It takes a little longer, but, for more accuracy, turn the wheel 20 times.
Rear end swap required & I'm cunfussed datsun dale Transmission - Rearend 8 12-17-2008 09:03 AM
rear gear ratio with 700R4? 68firechicken Transmission - Rearend 4 08-06-2006 12:58 PM
trans and rear end ratio choice? bonzipenguins Transmission - Rearend 7 05-08-2006 07:35 AM
59 vette rear end ratio? 1oldie Introduce Yourself 1 11-09-2004 10:19 AM
Rear end Ratio halcydbe Engine 7 09-05-2002 11:49 AM
