Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Way to check the rear end gear ratio...........
Old 06-19-2007, 12:51 AM
jimfulco jimfulco is offline
If you checked with both wheels off the ground, the wheel on the far side might have turned while you couldn't see it, and thrown your result off. Do it like F&J said.
Your dad's way is correct for a posi rear end.
