Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Which way does the low reverse roller clutch assembly go?
Old 04-21-2011, 05:38 PM
tnsmith10's Avatar
tnsmith10 tnsmith10 is offline
when will it rain???
Originally Posted by old yukon
Thanks again for the reply tnsmith10.
Ok, I took the inner race out. and it only went in like image B, with the inner tabs facing up.
I then installed the snap rings. Then tried to to put in the inner race, but it would not go in either way.
I can fit the race into the roller clutch assembly, but cant get them both into the retainer, or
I can fit the roller clutch assembly into the retainer, but then can get the race to fit.
Getting all three to fit seems impossible.
I must be doing something wrong here, it cant be that hard.
Waiting for more ideas !
once youve got the roller assembly in the center support. the inner race has to be "rolled" in at a very slight angle. its not easy, especially for the first time, when i was a teen at my dads shop i built 350's ( or engine or cylinder head rebuilding) during summer break from school, and it took me what seemed like forever before i could get the inner race to go in.
i recommend that everything is dry as it will help the race catch the rollers and "roll" in place. ive tried assembly gel or other lubes, and it was just a slimy mess that didnt work for me.
oh and your right, it does go in like in pic B. i should know better than that 1st thing in the morning when im not quite awake yet. from the front side showing in the pic, if you face towards you, the race should turn clockwise.
