Way to make bigger bolt circle fit a smaller one? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-19-2008, 03:32 PM
MrPhotographer06's Avatar
Army Strong
Last wiki edit: How to remove a VW Type I body
Last journal entry: well once again
dude here has some firebird rims he wants to sell me . bolt circle 4.75" i think my dip is 4.50" is there a way to make them fit?
Old 04-19-2008, 04:37 PM
techinspector1's Avatar
Wiki Edits: 326
http://www.ezaccessory.com/Wheel_Ada.../5450-5475.htm
Old 04-19-2008, 05:31 PM
leldai73's Avatar
Its just metal,you're the boss
find wheels that fit.
Old 04-19-2008, 05:38 PM
TooMany2count's Avatar
A Half Crippled Old SOB....
Last wiki edit: GM RPO build codes Last photo:
Location: Cahokia,IL..... Donate Blood Products & Sign your DONORS CARD
Wiki Edits: 5
4.5 is either ford or mopar bolt pattern & if you have a Mopar they won't fit w/out an adaptor.....joe
Old 04-19-2008, 05:42 PM
Army Strong
yeah. dodge diplomat..
crap.. maybe someplace has them cheeper
rims are 50 bucks..
Old 04-19-2008, 06:50 PM
Wiki Edits: 31
AMC also
and I have to put this to make the message long enough lol
Old 04-19-2008, 06:59 PM
Wiki Edits: 5
Originally Posted by matt167
AMC also
well matt you would know about the AMC part
&&& I forgot..joe
Old 04-19-2008, 09:50 PM
Originally Posted by techinspector1
that should do it
Old 04-19-2008, 10:22 PM
RODDER18's Avatar
Free advice....Don't use a spacer. Purchase wheels that fit the car. I have used wheel adapters and almost had a wheel come off the car. They also change the back spacing.
Old 04-19-2008, 10:41 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
I stuck a Ford 9" under the rear of a Chevy car and in order to have the same lug pattern front and back I found a set of rotors that had an alternate bolt pattern drilled in them staggered about 35 degrees off the original. This allowed me to use a factory hub and rotor with the larger 5x5" pattern. No adapters required. I doub't you'll find something like this for a Diplomat but you can always take your hubs and rotors to a machine shop and they should be able to drill the necessary pattern for you. It might not be cheap though.
Old 04-19-2008, 11:21 PM
leldai73's Avatar
= Blazin72 you can always take your hubs and rotors to a machine shop and they should be able to drill the necessary pattern for you. It might not be cheap though.
true, they probably could. but after paying for having them re-drilled, and having to have them re-drilled every time you change your brake rotors the deal you get on those rims is kinda null and void...I'm all for doing what you can with what you have, but your looking at a headache here, just find some rims that fit.
Old 04-19-2008, 11:45 PM
Blazin72's Avatar
Wiki Edits: 19
Never said it was practical for everybody, just that it was doable.
Old 04-20-2008, 12:37 AM
All those Mustangs, every Lexus & Infinity 6 cyl & above, all Honda CRVs & Pilots, a bunch of Toyota cars & 2wd pickups, late model Cadillacs, millions of Fords, all those Jeep Cherokees & Grand Cherokees, and a bunch of Mazdas with 4.5" circles (not to even mention the Chryslers) and you can't find any rims?...
Hey...seriously, I have a set of Camaro IROC rims that I had re-drilled to a 5" circle to fit a Chevy 1/2 ton pickup pattern. There was plenty of material for it, and they pressed in steel inserts. Looks like factory. I think I paid about 15 or 20 per wheel.
Too bad they are not your pattern...
Old 04-20-2008, 07:52 AM
leldai73's Avatar
having the wheels re-drilled is something to think about, as long as theres enough material to be safe, and the back spacing is correct.
no offense blazin72, you said it wouldn't be cheap, I was just agreeing with you.
Old 04-20-2008, 10:44 AM
Blazin72's Avatar
Wiki Edits: 19
None taken, I know sometimes it's hard to tell the nature of ones response over the internet.
Just don't call be "Balzin72" again.
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 06:57 PM
Best V8 for 1969 AMC Rambler? 1983lux Engine 15 12-08-2008 09:43 AM
body panel alignment gmonkey Body - Exterior 5 09-01-2003 06:50 PM
Th350 going to break, how to make spacer plate holes smaller? Jason Transmission - Rearend 7 06-30-2003 10:29 PM
CAN I MAKE MY GM 12 BOLT STRONG ENOUGH TO HANDLE THOUSAND HORSE CAR????? bigbad66chevelle Transmission - Rearend 5 04-11-2003 07:54 AM
