-   -   Weak 3rd gear (http://www.hotrodders.com/forum/weak-3rd-gear-223133.html)
4L60E 08-20-2012 06:53 PM
Weak 3rd gear
I have a 04 Trailblazer that slip going to 3rd gear only at light peddle. Change fluid and filter. Anyone want to tell me what is the fix?
S10 Racer 08-20-2012 06:57 PM
Alot is the way the motor has been used. If you do alot of heavy towing or running hard, things are going to wear out more quickly. Alot has to do with maintenance (frequent oil changes, fuel filters, air filters, etc.).
Crosley 08-20-2012 06:59 PM
Is this subject you wish to discuss in this thread ? At first the thread was about engine compression
S10 Racer 08-20-2012 09:19 PM
Yeah, I'm :confused:
4L60E 08-21-2012 04:56 AM
I change treads at the last second after I post it, I realize I was in the wrong forum. So I deleted that tread and posted what you see now. Please give me a small brake. This is my first time in a forum.
bigdog7373 08-21-2012 04:13 PM
No biggie.
To answer your question, you could try Pulling the valve body out and cleaning it up
4L60E 08-21-2012 08:41 PM
The 2nd. apply valve was bad in the servo.
4L60E 08-21-2012 08:42 PM
The 2nd, apply seal was leaking.
