Weak Line Pressure on Rear Drums - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-18-2010, 04:05 PM
Sweet-34's Avatar
Lost In The 50's
I have a '49 Merc Sled with a 327-Turbo 350. It has a Nova Sub and a 68-69 Camaro Rear. I have a 7" Power Booster with a Corvette Style Master Cylinder and a Combination Valve (all new). I'm running 2# residual on the front and 10# residual on the rear as the M/C is under the floor below the calipers. The M/C is shallow bore with the matching booster with proper measurement between booster and M/C.
I have great front Disc Brakes but very weak pressure to the rear drums. Everything is new on the rear including brake rubber hoses front and rear. I'm pulling 15-16# vac at 800 rpm.
Residuals are installed correctly with the out pointing to the rear and MC pointing to the Master Cylinder.
Rear wheels can't be turned when on jack stands when you apply pedal. Release and spin freely. The shoes are adjusted properly.
Hit the brakes hard on a dirt road and front wheels slide....rear wheels don't. Appears to be not enough pressure getting to the rear.
All advice and suggestions appreciated. Thank you~~~~Ron
Old 09-24-2010, 07:06 PM
try replacing the hydraulic Y box in the rear, it should have a main brake fluid line running to it and then Y's to send fluid to both sides. it should be up above the axle by the differential cover. do the rear brakes squeak? if not then there is fluid going to them, but not enough to activate the brakes. try changing the splitter i have replaced them in my trucks a couple of times they usually run about $20. good luck!
Old 09-24-2010, 07:21 PM
Sweet-34's Avatar
Lost In The 50's
It's all new....including rubber line and splitter. I think I gaining on it..........Low vacuum........bring the rpms up to 1200 or more and brakes work and vac is about 20. Looking for source of vac leak!!!!
Thanks for your reply~~Ron
1937 chevy coupe rear brake drums a70dart Suspension - Brakes - Steering 2 05-04-2010 09:16 PM
700r4 line pressure check...Crosley..anybody uncleaud Transmission - Rearend 1 02-24-2009 09:01 AM
Fuel pressure gauge moves to 0 on start 406 bug Engine 27 12-02-2008 05:39 PM
Tranny line and rear cross member question. Bo_Jangles Transmission - Rearend 3 03-08-2002 09:18 AM
