weak turn signals - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-24-2006, 12:43 PM
weak turn signals
Just got a call from a friend with a turn signal problem.
He has a stock 1950 ford (6 volt system) He installed turn signals in the car, which he says are working except that the bulbs are showing up very weak.
Any insights here? Grounding maybe? Thanks!
Old 08-24-2006, 03:28 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
Grounding IS always the Very First line of troubleshoot..as well as corrosion Control and proper bonding...Clean the sockets from corrosion, as well as the socket pads the lamp rests on, and inspect spring preload....be sure the ground sides are properly bonded to a CLEAN, Burnished , Hard ground, and use a proper star washer and lock washer. Sometimes we assume (because it automatic to us ) That it has always been checked first..and overlook posting that as a first step!
It may also be that what he has done (depending on the type Bulb he has in the tail Turn/ Brake lamp bucket) He has wired the wrong filaments..and has brake lamp / turn to the Lower (less bright filament) and tails to the upper (more brighter) filaments..He needs to check that..
Be sure the flasher unit is a 6 Volt flasher (not 12 volt, although it normally would not work or just hang on..stranger things have happened..)
How are the brake lamps? are they bright? that may be a clue as to the filament selection.
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 08-24-2006, 05:35 PM
He says the lights are dim when he hits the pedal. I'll pass along your info. As always Doc, Thanks!
Help! Tail Lamps, but No Turn Signals or Brake Lamps 41willys Electrical 12 01-02-2006 08:11 AM
dash lights and turn signals - again SteveMach1 Electrical 2 12-13-2003 10:22 PM
Adding turn signals to '53 Ford P/U first timer Electrical 4 12-04-2003 04:37 AM
Wiring Tail Lights & Turn Signals horvath Electrical 15 04-30-2003 05:04 AM
turn signals impala dreaming Electrical 5 02-24-2003 06:29 PM
