Wearing Out Deadmans Rubber Blocks? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-11-2009, 09:13 PM
FRANKBULLITT's Avatar
Anyone have a better way to shut off the sand blaster deadman control than using that silly little rubber block that wears clean through in no time thanks
Old 09-11-2009, 11:00 PM
Maybe a ball valve,but it too would eventually wear out.
Shane
Old 09-12-2009, 06:23 AM
shine's Avatar
Last journal entry: some progress
your dealing with abrasives. anything you use will wear out. just part of the job. my tips are 70 each and wear out too.
Old 09-12-2009, 06:43 AM
powerrodsmike's Avatar
Wiki Edits: 161
They last a lot longer if you open and shut the valve quickly, let it snap shut. Don't feather the valve, or leave it in a partially open position, this lets abrasive flow over the rubber, wearing it out...Same goes for a ball valve.
But yes, anything in contact with abrasives under pressure will wear out.
Later, mikey
BE different....ACT normal.
Restoring ABS Plastic and Rubber Coated Trim starquest Body - Exterior 3 07-16-2009 01:50 PM
Bad rubber fuel lines ScoTFrenzel Hotrodding Basics 4 01-06-2009 02:48 PM
Nice sanding blocks. Really. rrmccabe Body - Exterior 9 07-20-2005 07:55 AM
Squeaking rubber shakle bushings Larry Day Suspension - Brakes - Steering 4 08-25-2003 10:40 AM
350 blocks 010??? 78 monte Engine 3 08-08-2003 12:00 AM
