weather striping help? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-09-2013, 06:46 PM
I have a 1981 Pontiac firebird and some of my weather striping is gone and I don't know what it is call. It's the strip that goes in the door between the door and the window thanks
Old 04-09-2013, 08:22 PM
It's different on different cars but on the older cars it's referred to as "cat whiskers" or "fuzzie strips"
In '81 depending on the model it may have had a rubber with felt.
Old 04-09-2013, 08:24 PM
Maybe these?
sweeps
or these?
felts
Old 04-09-2013, 08:38 PM
It's is the felt thanks since my is gone would it cause it to leak thanks
Old 04-09-2013, 10:17 PM
If the seals (I call them anti-rattle strips) aren't there, you'll get more water running into the door but it shouldn't get inside the car. The water should run out the drain hole(s) in the door to the outside.
Old 04-09-2013, 11:55 PM
I am getting water in floor board what should I look for to stop it thanks
Old 04-10-2013, 12:16 AM
Water could be coming in around the doors. How are the door gaskets? Another prime suspect is the windshield. Look under the dash for rust or water. You can get the floor as dry as possible and have someone put a hose to the different areas that could admit water, while you try to spot where it is coming in. Start low and work your way up to pinpoint the leak. There are other places you could get water in but that's a start.
Old 04-10-2013, 07:20 AM
I have been in it when it's been raining and it's not the windshield and it's just wet right in front of my driver side seat and it not wet any where else thanks
Old 04-10-2013, 08:01 PM
Then it's most likely the water is coming through the door gaskets. Or you might have rust holes in the floor.
Old 04-10-2013, 08:45 PM
I just figured i would ask but does this car have t-tops or a sunroof, they are known for leaking in the area you have mentioned. Or even right on your lap as your driving. LOL!!
Old 04-10-2013, 08:57 PM
Oh yeah Mr4speed, never thought to ask that!
Old 04-10-2013, 09:17 PM
No it's not t-tops or sun roof I think it is the door seals my problem is finding them nobody around here has any thanks
Weather striping pros and cons nicksowinski Body - Exterior 5 02-17-2010 07:56 AM
Striping MrPhotographer06 Body - Exterior 1 01-02-2009 09:06 PM
Striping in new paint 54oldsguy Body - Exterior 18 10-16-2007 08:37 PM
Wife's first striping. Magnus_Jager Hot Rod Art 8 08-13-2007 04:55 AM
replacing weather striping on door CJ882 Body - Exterior 1 06-17-2005 09:57 AM
